Disables Ethernet OAM on ports.
port_list |
Specifies the particular ports. |
all |
Specifies all fiber ports. |
Ethernet OAM is disabled on all ports.
Use this command to disable Ethernet OAM on one or more specified ports or on all fiber ports.
When operating as a stack master, the ExtremeSwitching switch can process this command for ports on supported platforms.
The following command disables Ethernet OAM on port 1:
# disable ethernet oam ports 1 link-fault-management
This command was first available in ExtremeXOS 12.3.
